Hi i have purchase sony E3 dual , a month back, now i am facing a seriour problem, whe i tride to power off my device it hangs up in shutting down process for an hour, but i an see the back home and perious app buttons at bottom and also i can able to slide down the upper slide , what should i do to close the power off popup, please help me
That's quite odd, press and hold power & volume up for 5 seconds, it seems that perhaps an app its causing this issue.
It'll be wise to backup and repair your phone with PCC
Bridge (for Mac)
You often see this on computer s where by an app is still being stored in the RAM and is unable to be cleared so that the command to shut down can be actioned which I will assume is the current predicament you have so I would perform the actions above as Uli has said
