Somehow the proximity sensor doesn't turn off the screen. Do you have any cases, screen protectors that could interfere? What about 3rd party apps like task killers or antivirus?
sensor is ok.when i hit power off button touch is still on ~1 second and i can manage widget on lockscreen.its not only my problem,you can find info on 4pda.ru in Xperia Z1 section if you know russian
at direct sunlight i can see that after i press power button - screen is not OFF! only the backlight go off
Sorry to hear that you have issues after the update.
We are aware of this issue and it will be fixed in an upcoming software update.
