I bought kitkat version of Xperia Z1. There are two issues of cameras.
1: Cannot save images to SD card. Saving fails 100 percent.
2: Front camera issues
2-1 Front camera freezes with black screen.
2-2 After test (Dial *#*#7378423#*#*), The result says Camera does not connect to device.
Some users are experiencing the same problems.
Although I reported these issues, Sony has not replied yet.
Probably, after Android updating to Kitkat, those problems appear.
Does this happen with just one SD card ?
my camera just freezes and i have to switch off loose the picture then reboot whole **bleep** thing to get it to work again, any clues to get it to work properly
settings > apps > all > Camera > clear data > check again
Yes it does. Images cannot save in SD card. It can save in memory.
I carried out this solution. Issue has not solved. It happens again
Did the trick!
