problems after Xperia SP 4.3 update
windigox5
The update to 4.3 was very good but there were some problems...
1) volume control doesn't appear... If I use the downloaded themes..
2) while using the original themes..if I change from the air theme to the sunny theme.... Only the wallpaper and lockscreen change... But the THEME REMAINS that of THE AIR THEME...
3) the phone sometimes FORCE SHUTDOWN all by itself... EVEN IF there are no problems...
12 REPLIES 12
windigox5
@ alexdon Reinstalling using Sony update service doesn't help... The problem remains... It maybe a bug problem..
profile.country.RO.title
_alexdon_
You might want to visit a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
dm84
Contributor
before you try to repair via sus you have to backup firly via pc companion ,then facyory reset your device once restarted , switch off then connect to sus (sony update service)to repair your device .
