Problems with Exchange sync after update to Lollipop
GoaDuke
Hello Support forum,
first excuse my bad english, i try my best to explain my problem as well as possible.
Last week i update my Z1 compact to Android 5.0.2.
Now i have some Problems with syncing on my Exchange-accounts.
I use 2 Exchange-accounts, one for email and contacts and one only for calendar. Only these options are enabled in the settings of these accounts.
After the update ist seems that both accounts sync everything and not only the enabled parts.
How can i supress that?
And a second question is: Is the option "Sync tasks" for syncing tasks from the Exchange-account?
I hope my explanation was not to bad and someone have some ansers for me.
Regards GoaDuke
1 REPLY 1
Bandolero
Contributor
Regards GoaDuke
Hi GaoDuke,
I'm not sure which what you do not it to be synced, hope i get you correctly.
Can you elaborate more that what you wish not to be synced?
