Problems with temperature from M4 Aqua
willschou
Well. I Update my phone to Android 6.0 MarshMallow and Now, is overheats. I don´t know what i do. the phone xperia start and the temperature is 39ºC.
2 REPLIES 2
Uliwooly
@willschou
repair the phone with XC and report back.
Emir1
Hero
Hi @willschou,
Does the device give you a warning, or turn off due to heat? It is normal that the device heats up during use, but how do you mean that it behaves after the update? Does the device constantly turn off to cool down?
My recommendation is that you see if the device generates heat in an idle state as well, and in case it does - see if the same thing happens in safe mode and report back.
