Recent apps overview not working properly
Fury82
So, the overview for recent apps tends to not show me anything in the last few days... I use the phone a bit, and nothing there anymore. A restart solves the problem, but after some time... Boom... Does not show any recent app.
Anybody got some of that suggestions? 🙂
23 REPLIES 23
Uliwooly
@Fury82
does it happen with all apps or just specific apps? could you use the phone in >>> safe mode for few hours and test it
Netjer_Draconie
when I click on the rectangle the apps used recently are usually displayed. Since a few days it happens that here nothing is displayed. Where can the fault lie here?
profile.country.RO.title
_alexdon_
@Netjer_Draconiedes rectangle? You mean apps menu?
EDIT: I think I understand, the recent apps manager. So the apps you have been into are not shown there?
alexdon
Netjer_Draconie
I meant the apps used recently. The menu on the smartphone display where all apps appear that I have used recently
Netjer_Draconie
Yes, the apps are not displayed
_alexdon_
Have you installed any task killers? Those might have access to clean up that field.
alexdon
Netjer_Draconie
This error does not always occur. If the smartphone is a half-day on, I have to 90% this problem.
Netjer_Draconie
What are killer task?
Netjer_Draconie
Task killer.
