restarting
ukforty1
restarting
Hello everybody, my phone was 4 weeks at sony center for repair, now it back and again same bug: when I go to accuweather web page,clicking on accuweathet widget it has restarting what can I do? I don't want to send it to phonecentre again.
Tags (1)
4 REPLIES 4
Thommo
Try performing a system repair as this will often fix issues - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
ukforty1
Thank You Thommo.
JAYROKES
hello everyone,my phone is restart at once in day may be high use of games but why its happend
first screen turn of yellow colour than its restart
ukforty1
Try use it in safe mode, some third part aops can make this.
