Restore data to pc from sd card
oyvin
Hi, my z1 compact got destroyed, but the sd card where i saved the backup/restore app data is still working, how do i recover that data to my computer via the sd card?
5 REPLIES 5
profile.country.RO.title
_alexdon_
Do you have a card reader to use with your computer?
alexdon
oyvin
yes
_alexdon_
The media files are available on the card itself, you can navigate to DCIM-100andro to find the photos for example.
As for the other files or specific backups, you need another device to restore them to.
alexdon
oyvin
could this be a different brand device even though i used sonys built in back up and restore program? and in that case how?
_alexdon_
Well if you used the inbuilt option, don't think you can restore on a different device.
alexdon
