Running without phone problem
kiikooo
Hello,
So i have been running for the last couple of days and on the first day i ran for 20 minutes but did not have my phone on me. The smartband showed that i was running and counted 20 minutes on the walking/running menu.
Then i go back and it syncs with my phone and the running is gone and is now counted as walking.
The next day i had my phone with me and that day is still recorded fine.
Then today i left my phone back again and same thing happened. After my workout it clearly showed my running minutes then after syncing with my phone i lost it and it was considered as walking.
Anyone else noticed this?
Any suggestions?
Thanks
3 REPLIES 3
paul28
Haven't run without my phone but with my new SWR30 yet. First try at that will be Monday.
But I do notice in Lifelog -> Settings -> Logger you can choose wether to use the phone's sensors to log an activity and/or the SmartWear's (ie, SWR30). Which options do you have enabled? I've got SmartWear only to avoid the phone doubling-up an activity or, as you might've found, overiding it - as I wasn't sure how smartly the two play together.
kiikooo
Oh i never checked that before.
I had everything enabled. Should i uncheck all except for application?
Since also when i am at school, and check the map. I find that its showing that i've been home a couple of times when i never left the school.
You think it is related?
kiikooo
So I unchecked everything except for application usage and after going for a run, the watch recorded 20 minutes. Then when I got back to my phone now it says 5 minutes on both phone and band and also shows I was in a car during that run.
It is definitely messed up.
