screen auto-rotate
earl78
screen auto-rotate
Since the update Screen Auto-rotate takes forever, if at all, can take any thing from 3mins to me having to use the red button to turn the phone off?
3 REPLIES 3
Thommo
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
earl78
Done all this already, I must have done 15 system repairs in the past 3 months
dynamicbio
Settings>Display>Screen Rotation, check if you have smart screen rotation on or off, if that is causing you any issues
