screen sensitivity z3
CasualGamer
Is there any way i can reduce the screen sensitivity in my z3? I found that underwater screen clicks itself
5 REPLIES 5
Jake-SonyXperia
Champion
Hi CasualGamer,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
Are you only using the Camera under the water? as the device will only work when the handset has first loaded the camera, and then using the camera button to take the picture.
No other services can be used when the device is submerged due to the fact that the screen will not be functional.
CasualGamer
The problem is that the screen is functional
profile.country.RO.title
_alexdon_
It is normal that the screen behaves like that under water. I suggest you grab an app called touch block as it is useful.
alexdon
CasualGamer
So there isnt any way to reduce screen sensitivity by any setting or app?
_alexdon_
Touch block app will do what the name says. You can take underwater pictures with it.
alexdon
