SD card damaged message
Not applicable
Hello all.
I have just turned on my Xperia X10 Mini and on the top of screen there icon and a message telling me that the SD Card is damaged and should be formated. I try to format it through "configuration > Sd Card > Format SD Card > Erase" however nothing happens. I have rebooted the phone, and checked that the SD Card is well conected, however I the demaged SD card message still remains. What should I do?
Thanks,
Samuel.
1 REPLY 1
Not applicable
Ok first question I have to ask is was the card working correctly previously? The reason I ask was that there is a spate of fake sd cards around at the moment they work fine up to a certain size then past that they are corrupt. I have so far bought 2 of these and ended up with similar problems.
