Sony Audio Recorder
e-kzn
Sony Audio Recorder
Hello. It is still not fixed the problem: The recorder stops recording when I start playing music with Walkman. BECAUSE I listen to music through the SBH-80, it does not interfere with the audio recording. And other recorders do not stop recording. Correct the problem in your recorder.
Sony Audio Recorder: https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.audiorecorder
6 REPLIES 6
Uliwooly
That's normal, try to play music and then if you have a smartwatch 3 use ok google and the music will stop, or use ok google on the home screen on your phone while playing music
e-kzn
This is not normal. Only the voice recorder from Sony stops recording. The rest of the recorders work fine. And they continue to record sound.
Uliwooly
have you contacted the app developer directly? keep in mind that this is a user based forum.
e-kzn
Why, then, Developer World and local support Sony offering the first thing to write about all the problems in the software talk.sonymobile.com?
Uliwooly
That's odd, I don't understand the reason why.
e-kzn
Comrade @Rickard :)) Pay attention to this problem)
