Sometimes music hangs for a very short moment or somethimes when screen is locked after 15 second will stop working for 1 second or ~ 0.5 second
If I will install update 8.4.A.5.4 will work better ?
Sorry, but i don't speak english very good .
Thankyou !
You should try the new update and also try this
settings > apps > all > walkman > clear data > check again
is your music stored on a SD card or internal memory?
is stored on a SD card
That could be the issue, which class is your SD card ? 2, 4, 6, 8, 10?
First of all THANKYOU for your reply !
Now I have class 4 SD card.
If I will buy a 10 class SD card this issue will ocure again ?
It shouldn't but if it does then it could be an app acting up, such a taskiller or antivirus
