Hi, just wanna ask if anyone is encountering occasional not responding on their Z1? I am frequently encountering the System not responding message box. Even if I am not using the phone. When I try to unlock the phone sometimes it just does not respond for a while then just run again after a while. Not sure if this is software issue or hardware?
Android version: 4.3
Also, I am not encountering this before. Just recently and I have not yet updated my OS since i bought it.
Any info would be really great!
Have you installed any apps that you may consider unwanted which could be using up system performance thus slowing down your phone to the extent that it gives this message - All I suggest is backing up all info and performing a system repair then monitor your situation - If it continues without installing any apps then I'd consider it to be a hardware fault - If nothing happens and it perform well then install apps one at a time and monitor if only to see if you can track down the app if it is in question causing this issue
