My Sony Experia won't charge, battery is dead. i can plug it in and will actualy say it's charging and red light will stay on, even though do have connectivity issues and disconnects. but no matter how long it says its charging it wont go above 1%. I am From UK but currently on a working holiday on Australia.... it is plugged into the mains socket in my hostel and has worked in the same place for the past 2 weeks but now doesnt. I've tried reseeting it at the button at the back, no fix. tried to back up and restore but it turns off before back up finishes... So don't know what options i have other than trying a reboot...
Connect your phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2 to 3 hours
pressing those buttons doesnt seem to do anything. still wont charge...
Follow my advice step by step and let it charge for 3 hours, even if it doesn't seems that its working, if after 3 hours it doesn't power on then you will have to wait to contact your Xperia Care
