Switching from vibrate mode to ring mode
salahpausini
Hi everybody.
I'm a possessor of an Xperia Z5P Dual and since I updated my phone to 32.2.A.0.224, when I receive a call while it's on vibrate mode, it vibrates normally and when it stops, it switches to ring mode and I have to put it, again, everytime, on vibrate mode. Before, I have never had this problem. What's the solution?
I, now, see a new research bar on the top of the phone that didn't exist before. Can I remove it?
Thank you. 😃
6 REPLIES 6
Uliwooly
@salahpausini
Could you test it in >>> safe mode
Jake-SonyXperia
Champion
Hi salahpausini,
Just to clarify, are you saying that the device removes it self from Vibrate mode and starts making noise only when a call comes through?
salahpausini
With the first call it stays in vibrate mode, after the call ends, it changes to ring mode and I tun it myself into vibrate mode again.
KaterinaSto
I have similar problem with xperia z5 compact. It turns do not disturb mode off randomly: after I receive an income call, as described above, or just when it's in my bag/on my desk inactive, or it has done it just now while I was searching for solutions in this forum. The fix would be highly appreciated, because it is very annoying when you turn do not disturb on before the meeting, and then in the middle of it the phone starts making sounds.
profile.country.PH.title
MarlonUk1
the DND option has three modes,. total silence, alarm only and priority only. each can be activated indefinately or with time lapse. so make sure you configure it before using.
salahpausini
Even when I make a call, it is desactivated automatically, just after. The problem is on the new update "32.2.A.0.224" because I havent' had this, before!
