unfortunately acore.process.have stopped
happyfeet
Hi
I keep getting a message on my phone that unfortunately the acore.process had stopped.
Why am I getting this message and what do I need to do to stop this?
I have requested support from Sony with regards to this and I'm still waiting.
1 REPLY 1
Thommo
Try performing a system repair as this will often fix issues - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
