Unlinking Ringer & Notification Volumes
mowens74
Phone: Sony Experia Arc
Android Version: 4.0.4   /   Build Number :  4.1.B.0.431
Since upgrading my Xperia Arc to Ice Cream I have had problems, problems that didn't exist prior to the upgrade.  I was advertised to do a Factory Reset, which appears to have resolved the issues I was having but now I have another problem.
Before the Factory Reset I was able to unlink the Ringer and Notification volumes, I am not unable to do this.  Originally it was in 'Menu > Settings > Sound & Display > Ringer Volume', but it isn't there now.
Is it still possible on this version of software, if so where is the option.
Thank you.
3 REPLIES 3
FrontierGate
Contributor
This is a feature of ICS. (Ringtone and Notification Volumes together)
I don't understand why Google link them together.  It is also like this in Jellybean, too.
mowens74
So does this mean, with the Ice Cream software I am no longer able to unlink them (just clarifying)...?
If we can't, does anyone know if there is somewhere we can place suggestions for updates to the software..?
Thank you
belgianinturkey
Hi everybody,
I have the salme problem with my Z3.
As said here it is linked to the Android version. Android should get better and not worse with updates !
I want to throw my new Z3 in the garbage and use my Motorola again becouse i don't want to jump up at every notification coming in ! Only when I get a phone call.
Hope there is a solution soon !
Tags (1)
