USB connection problems? phone gets partly connected
nada14
since connecting the phone to the pc is the only way that i can transfer my data, photos and videos to clear the memory.. i face a problem since the pc does not recognize the data on the mobile.. it does not appear in my computer..when i connect it tjust the install media go and pc companion opens... what can i do plz to solve this issue and transfer my mobile data to the pc?? thanks in advance
3 REPLIES 3
profile.country.RO.title
_alexdon_
Enable MTP under connectivity settings.Take a look here too:
http://talk.sonymobile.com/t5/FAQ/USB-connection-problems/m-p/348074#U348074
alexdon
nada14
it is already enabled automatic since i have no other option except MTP :S
Thommo
Do you have developer options enabled and USB debugging - check settings then just above about phone at the bottom, If you don't see Developer options then it's not enabled
