Hello Support Team,
I tried to unlock my bootloader, i received the verification E-Mail and clicked on the link in it, but the destination of this link is only showing an error-message:
Fatal error: Cannot use object of type WP_Error as array in /var/www/wordpress/wp-content/plugins/unlockbootloader/model/ublstep_3.php on line 121
This is the link i received (i removed a few characters from it)
http://developer.sonymobile.com/unlockbootloader/imei-verification/74564b7fe17420576dd9094a........
Please fix.
Thank you
Not sure what the issue is - Is it the url received or that from what I've seen on the web you want to install CM11 - If the username on this other site is you then you simply haven't installed the Fastboot driver correctly
the verification link received is not working. When i klick on it, i receive this error-message in my browser.I can't continue to unlock bootloader on the sony websites. I'm not even started doing anything to my device.
edit: now it works.
If you have received your code then you don't need Sony - Download Flashtool and install then run the program and select BLU and follow the onscreen instructions, It will ask for your key, The program will do the rest
