Vibrations impossible to stop
shelby
Hi
My Xperia S started vibrating constantly 5 hours ago. It is impossible to stop. I have turned the phone off, and it is still vibration even turned off. I have reset the phone (volume up + on/off) but still vibration constantly. Everything else on the phone work perfectly normal. Don't looks like a software problem actually, more like if there is some short cut to the vibration motor.
And of course to make everything perfect the the warranty was ended 13 days ago!!!!!!!!!!!!!!!!!!!!
Any suggestions?
1 REPLY 1
Jake-SonyXperia
Champion
Hi shelby,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
In this instance, you will be required to get the handset to a service agent as this sounds like hardware.
I suggest that you contact Sony mobile directly to further help.
http://support.sonymobile.com/global-en/contactUs/
