Can someone tell me how to set the voicemail number for my phone?
I just recently got it and it doesn't have a set number for the voicemail.
I can tell you exact way how to set your voicemail number for your phone if you tell me which phone you are using.
In most of sonyericsson phone which ever i'd used found it in "menu>messaging>call vicemail" if your voicemail number is not set then it can give you option to set it you can simply set it from there.
