Hi all,
I noticed such an issue in my Z5.
Sometimes when changing the volume of the phone (no matter up or down) it happens that this small dropdown icon does not appear. You know, the one that you should be able to click and then select what type of sound you want to adjust:
1. the phone volume,
2. entertainment volume (music, games, videos etc.),
3. alarm volume
I am not sure why it happens randomly, but it was the same on previous versions of software as well. I am on 32.2.A.0.253 currently.
Unfortunately I am not able to make a screenshot of it as only you are trying to make a screenshot this function (volume) is hiding. Hence I decided to recod my screen which I will post here soon if there is such an option to show it here. Are you experiencing it sometimes as well? I do not know the reason why it happens randomly.
Thank you,
I'm facing the same issue since the first MM update.
The dropdown icon sametimes is not there.
Connecting my sony sbh50 bluetooth headphones, solving the problem for some time.
