the issue: after update to lollipop, my xperia z3 can be wake up by press volume botton
question: is there anyway i can disable volume botton wake up?
My phone doesn't wake up by volume buttons, either of them. Do you use a custom launcher?
lollipop update is done by sony software, no third party rom
I mean launchers like Nova Launcher, Apex, GO, any app that changes your homescreen.
thanks for your support
i just find an answer, a little tip for you all, after you push power button to lock the phone, you have about ~1 seconds to push the volume botton to change the volume or wake up the phone, after the 1 second gap, it will not wake up.
how did i found out? i just got the cover from spigen, and what they did is made a cover to cover all the buttons, so when i push the volume botton, it will affect the power button to be pushed as well, but not noticable, so i remove the cover, got the above answer.
still a little tip for someone out there.
Nice tip, just tried that. Thanks for the info.
