w960i memory card
Not applicable
w960i memory card
Hi! I have the following problem with my phone. It can't find built in 8GB memory card. Few weeks it saw memory randomly. And now doesn't sees at all. Guy from the phone service said, that my phones main pcb is broken or so, and it can't be fixed as my device is no more pruducted. Computer doesn't sees phone as memory too. What can i do, to fix it?
7 REPLIES 7
Dr_Chris
Champion
Have you tried updating the software?
Not applicable
Yes, i did, but unsuccessfuly. When PC has downloaded software and trying to install, reports that, i have discharged battery, or others problems, but the battery is  full and cable is still plugged in.
Dr_Chris
Champion
Have you tried a Master reset?
Not applicable
Before I tried to update software i made reset.
Not applicable
I have the same problem, i oppened up the phone and foud the 8GB chip (it's on the back side of the sim slot). It's pretty easy to change it if u have another one that works. Does anyone know if the battery that is atached to it could have any influence on the 8gb memory?
Not applicable
I have changed battery, and it works fine.
konstadi
Anonymous(anon), could you please give the details of the battery you replaced (the new one), that made the memory card come back to life? I have changed battery but I still can't see the internal 8GB memory card to be present. Not even with a usb cable that connects the phone with a pc. I hope that with a specific battery like yours, I may use the extra memory.
