W995 delivery reports
Not applicable
I've just upgraded the software on my phone, but now delivery reports don't work. They are turned on in the settings. Any ideas ?
3 REPLIES 3
Dr_Chris
Champion
Check that the Validity period in your Message settings is set to Network maximum.Otherwise,re-run the update service and/or select the "repair phone" option via PC suite.If you happen to be on the O2 network, delivery reports only work for MMS but not SMS.
Not applicable
Trying the repair function now. Thanks.
Not applicable
It worked. Thank you. I also didn't do a restore this time, which may have helped. I just synchronized my contacts etc.
