Walkman needs a sleep timer and a lock screen widget
Stephandeluxe
I really would recommend a sleep timer and a lock screen widget.
3 REPLIES 3
Uliwooly
The timer has been requested before. As for the lock screen widget it is there whenever you play music.
Dhavi
I don't get the walkman widget on my lock screen while I'm playing music on either my headset or loudspeaker. I tried using different screen lock options as well. Using xperia z2.
ShrinivasPai
It appears normally when playing walkman. But disappears after installing sony smartkey app from suggestion of smart connect
