The world of Android applications is growing everyday with around 50,000 applications in the Android Market alone, you can find almost anything you want.
So, take a minute and share you favourite Android applications here. Are you a fan of games, or maybe productivity applications?
Thanks for sharing!
Doodle Jump is the most addictive game.
On the X10 it has to be JuiceDefender... without it my phone would need recharging around every 8 hours.
- Toshl
Found in Playnow free download. Tracks all your spending by categories with monthly summary. Great for the economy.
- WisePilot
Found in Playnow free download. Provides turn-by-turn navigation with voice. Free subscription for 2 years I think.
- Key Ring
Scan and save barcodes for store memberships. Nice interface.No more membership cards to carry !
- Bump
Send contacts info, pictures, apps by bumping phones together and also works with iPhones (many of my friends are using iPhone so this is great)
- XPERIA FlashLight
Activates the camera's LED light to use as flashlight. A very convenient 1 click on and off widget. And it's made specifically for Xperia X10 !
- Taskpanel
Kills applications in the background automatically. Improves my battery life by a lot***.
- APNdroid
Disable 2G/3G data but still allow MMS. (I don't have unlimit data plan).
*** I only used it for 1-2 days. Still not sure if it's this app or other things that made my battery life improve.
Toggles for wifi/GPRS/Bluetooth
Helix Launcher
Xperia flashlight.
Startup manager(life saver for battery)
ebuddy
R.thunder lite.
I've just downloaded the Apps Organizer, which is excellent. It enables you to sort out apps by categories - there are some categories already on it, or you can create your own. I have just organised mine and have created shortcuts on my home screen for "Japanese" and for "Games", with each folder containing a number of apps. If you like, apps can be listed in more than one category. Well worth trying out.
The tethering application that lets my X10 act as a wireless router while I am traveling across Canada. It really helps me out since I pay quite a bit per month to have a national data access plan. Tethering my phone to my laptop helps me do business while I'm out of the office.
Oh wait, I must have been dreaming. There's no such application because we can't install it as there is no ROOT ACCESS on the phone.
Hi
I was looking at using this phone (Experia) to tether to my laptop while travelling. Did you find a way to do it?
Regards
Edward
Password Keeper
Barcode Scanner
Use PdaNet.
Youneed to install one version on your x10, download from market, and one version on your PC, http://www.junefabrics.com/android/
