Who will solve ower problems , SE it self doesnt reply us !!
Not applicable
I have SE X2 ..
problems that i cant find solution
1- X button doesnt close the Applications and they remaining in the task manager
2- when a call waitting comes the sound of the voice conversation is heared from the speakers comes and goes as the waitting sound is heard .
and then sounds goes rude , music and phone notifications are played on the voice call speaker.
3- the ring tones and the added music is too low , i cant hear the mobile if its in my pocket !!!
4- the phone is too slow and takes time to load each application specially camera .
5- memory card suddenly nothing was found on it although i saved on it some mp3 and DCIM , then i took another pics and saved on it DCIM , suddenly the old things came back and my new dcim disappeared as it was the same name,
6- there is a blue dot on my screen just i can see it on any black back ground , its small dot i think its manfucturer issue , what can i do ?
i hope i hope sony ericson support reply , really i started to change my idea about SE .
1 REPLY 1
Not applicable
The "X" button works that way in Windows Mobile - it does not kill the running program, just puts it in the background like you can do on a computer using the "_" sign.
You could try install the free software "Magic Button". It changes the behavior of the X button so it actually turns off the running program.
About the other problems you have: If the last update does not fix them for you, send the phone back and clame a new phone or money refund.
