This is a very annoying issue in my SP. Without any reason and with any recognisible pattern, the WiFI, the Bluetooth, Auto-syn and backlight turn off automatically. I can be doing any activity that requieres or does not data connectivity and suddently the telephone has desactivated by itselft all the functions mentioned before. (I suspect that also happens with Mobile data but I never have it connected). I need to manually activate all of the functions. This happens very often many times a day and it is very very annoying. I have the latest firmware installed (254).
Any idea to solve it? Does anybody has experienced something similar?
Thanks
Is this happen in any percentage of battery??go to setting>power management>low battery mode...check setting there
I have it activated... let me do some adjustments, that might be the problem. I haven't notice that is related with battery compsuption, but it might be.
I will check it and let you know if it is sorted.
Thank you very much
