WiFi connection problems
AzMirza
Help
I have a Z2, but I cannot connect to wifi.  I have tried restarts, I have tried factory reset, I have run a diagnostic but the wifi simply wont switch on and therefore I cannot get the phone to scan for networks.  It worked briefly after I updates to latest firmware but that only lasted 5 hours.
The phone is only a few months old and in new condition.  I've no idea what to do.
Az
3 REPLIES 3
SophiaW
Enthusiast
Hi AzMirza
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You could try running a Software Repair on the handset, this will re-flash the software & is likely to resolve the issue.
To do a software repair, first download the PC Companion software and install it on your PC.
Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Please ensure your phone is powered off and not connected to the PC when you begin this process. You are not required to connect the phone until after step 10.
1. Install and open PC Companion then select Support Zone.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
10. Follow the connection steps
Hope this helps - keep us updated :smileyhappy:
AzMirza
Thank you very much for your quick response.  I've just started the process so I'll hopefully have some positive news.
SophiaW
Enthusiast
No problem AzMirza! Hope the process has been successful.
