Wifi Problem on Experia Z5
Blv
I have updated my phone with android6.0 but after that,no wi fi connections are detected on my phone.
Also I cannot use wifi related apps like 'Sherit' on my phone.
Digonistics say that my phone is working properly!
2 REPLIES 2
Uliwooly
Does your phone detect any WiFi?
Could you test it in >>> safe mode ?
Didrik
Enthusiast
Hello @Blv and welcome to the community!
Was there any change if you rebooted your phone to safe mode?
If you check under Settings > WiFi, can you still see your old saved networks or are they gone?
Are you able to manually connect to a WiFi network? To do so, go to Settings > WiFi > Press the three dots > Add network > Enter the required information > Press Save. Are you now able to connect to this network?
