this might mean a loose usb port or cable. try using another usb cable. or have your phone checked at your local service center.
for your battery problems, please use the search bar above and search "battery drain". you will find many threads reagrding this problem
Hi @sarahpalmer17,
Does your device have the same behaviour if you use another cable to charge your phone? If not then this is most likely caused by a defect or broken charging cable, should it behave the same way even with another cable I recommend that you contact your Local support in order to have your device sent to and examined by an authorized service center.
I can understand the inconvenience this may cause for you but I recommend that you have it sent to an authorized service center, especially if a part came out from the charging port in your phone.
Hi @davidnlaura2007,
In that case I can unfortunately only suggest that you as well have your device sent to an authorized service centre.
