Just got an X10 mini, new to all this fancy technology.
I want to put my music on it - but the only computer I have is an apple laptop, which doesn't figure in the instructions.
Can I get my music on my phone or am I doomed??
You need to download the Media Sync software onto your Mac from the SE website and then connect your phone up.
Easy,
1) use a card reader, transfer the music to the card
to be precise...
1. stick your memory card into the card reader.
2. look for the "music" folder in the root directory of your card.
3. Transfer all the music you want into that folder
4. Replace the micro-SD intoyour phone and start up.
5. The phone will mount the memory card and before too long, you will have all your music available to you.
* playlist should be in m2u format. If you are like me, owns some music with IDtags in other languages, save your playlist in UTF8 format.
