Dear All
After updating my Acro S from ICS to JB the proximity sensor stopped to work.
I've already tested with *#*#7378423#*#* and it shows always off in JB. When it was in ICS it was working well...
Any suggestions to fix it?
What do you mean by does not work?When you are in a call,does it turn off your screen while covered or the screen stays on?
alexdon
Exactly like this... during a call the screen is still on and I touch everything with the face
Have you tried covering the sensor with your hand to see if the screen goes off?
Yes... already tried but doesn't turn off, it is always on.
Also checked with the code 7378423 and it always shows "proximity sensor off"
Then it is not right.I am aware you may not want to do it,but I suggest repairing phone software with Sony update service or with Pc companion.
I tried this lots of times when I updated to .200 months ago, without positive result
Even not being recommended, I flashed back to ICS to have the proximity sensor working normally... I thought this issue have been solved in .96 update
I'm not in the same country I bought my mobile... so send to assistance is not a solution for me
Ok,you should wait for another update then.
Omg...
I hope that a Sony member is tracking this discussion to know about this issue...
It seem that I'm just the one who had this problem?
There were some people with Xperia P that complained about the proximity sensor(I am from Xperia P section),but I recommended repair and it was fixed.
