Xperia E4 laggy???
Prasad64
Xperia E4 laggy???
Xperia E4 is being announced . Getting many sites to see the reviews ....but recently got some videos on youtube which show that E4 is laggy in day to day operations...is that true?
https://www.youtube.com/watch?v=42adgBU80NI
https://www.youtube.com/watch?v=-wqv7qpuz6c
12 REPLIES 12
Thommo
Well that guy is an idiot and should be banned from owning devices for his own good - You make any repetitive actions fast enough on any device will result in a lag as the memory will not be able to keep up causing a lag which is your device trying to catch up, But if you want to believe an idiot then that's your choice.
Prasad64
Thanks a lot Sir. Actually i want to buy the Xperia E4 in exchange to my Xperia E3. But confused what to buy- E4 or E4G. The processor and gpu is better on E4G but dont know if it will be available in India.Last time too E3 LTE model eas not released in India. So I think I will have to go with E4 only.
Prasad64
I have heard the cpu and gpu of E4g are better over E4....is that true?And what difference are there in it?What can be the effects in day-to-day use?Are both the chipsets better over the predecessor- The snapdragon 400 n adreno 305 in E3 or not?
Uliwooly
Contact your local Xperia Care regarding this
http://support.sonymobile.com/global-en/contactUs/
Keep in mind that this forum is for us, users, to help each other, what you need is official information directly from Sony.
Uliwooly
Xperia E4
Mediatek MT6582
CPU Quad-core 1.3GHz Cortex-A7
GPU Mali-400MP2
Xperia E4 4G
Mediatek MT6732
CPU Quad-core 1.5GHz Cortex-A53
GPU Mali-T760MP2
Delta44
Wait wait wait.... I have sony xperia e4 dual e2115 but i have mali-400mp not mp2...
xperiaperson
It's mp2, but at many sites it says mp only.
As for which one to buy, I'd say E4g, it's superior in any way - from chipset, connectivity (it has LTE) to screen quality (color reproduction and ppi). Xperia E4 has slightly larger display (5 vs 4.7 inch) but that's it already.
Of course it's your choice, E4 is also slightly cheaper if that's important.
jinxycat
Device works fine, though some apps, like messaging, are very slow.... Should i erase messages that are loaded?
xperiaperson
Probably, if it has to load many messages it'll get slow. It's usually the case with all such apps.
