Xperia ion LT28h flashing problem
AaruneyRahul
I used the flashtool to update to JellyBean but i get the following error. My phone is not rooted.
14/041/2013 08:41:10 - INFO  - <- This level is successfully initialized
14/041/2013 08:41:10 - INFO  - Flashtool Version 0.9.10.1 built on 2013-01-09 19:49:47
14/041/2013 08:41:10 - INFO  - You can drag and drop ftf files here to start flashing them
14/041/2013 08:41:15 - INFO  - Device connected with USB debugging on
14/041/2013 08:41:15 - INFO  - Connected device : LT28
14/041/2013 08:41:15 - INFO  - Installed version of busybox : BusyBox v1.16.2androidfull (2011-06-09 17:40:07 CST) multi-call binary.
14/041/2013 08:41:15 - INFO  - Android version : 2.3.4 / kernel version : 2.6.38-android-x86+ / Build number : GRJ22
14/042/2013 08:42:19 - INFO  - Selected LT28h_6.2.B.0.211_Generic.ftf
14/042/2013 08:42:19 - INFO  - Preparing files for flashing
14/042/2013 08:42:22 - INFO  - Device disconnected
14/042/2013 08:42:33 - INFO  - Please connect your device into flashmode.
14/042/2013 08:42:46 - INFO  - Device connected in flash mode
14/042/2013 08:42:47 - INFO  - Opening device for R/W
14/042/2013 08:42:47 - INFO  - Start Flashing
14/042/2013 08:42:47 - INFO  - Processing loader
14/042/2013 08:42:47 - INFO  -     Checking header
14/042/2013 08:42:47 - INFO  - Ending flash session
14/042/2013 08:42:47 - ERROR -
14/042/2013 08:42:47 - ERROR - Error flashing. Aborted
14/042/2013 08:42:47 - INFO  - Device connected in flash mode
14/042/2013 08:42:50 - INFO  - Flash canceled
Moreover when i switch on my phone in flashmode, it stays in flashmode for 15 sec and then it goes to charging mode. Please help. 😞
7 REPLIES 7
Uliwooly
two possible problems
1) you have an old flashtool version, look for the latest and redownload it
or
2) you don't have the drivers, download and install SUS > restart your PC > disable your firewall and antivirus > run SUS > repair your phone > this will download the drivers, then flash it
AaruneyRahul
Update did not susceed even when i used pc companian.
Uliwooly
could you elaborate?
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
AaruneyRahul
Tried all, nothing is working. In all the problem is my phone is not being detected in flashmode.
Uliwooly
interesting, try a different computer
Bobbybr
try to use usb 2.0 not 3.0. mine , works.
Adish
I had the same problem, but then i tried connecting it into a different port in my computer, works like a charm Slightly_smiling_Face
