Xperia J Contacts problem
Lilykelly
I have a problem I'm hoping someone can help me with. I switched my phone off yesterday and when I switched it back on again there was an error message, can't remeber exactly what it said but it was somethign about android. What I did notice was all my contatcs were gone. I checked the filter settings which were fine and then tried to import my contacts back from the phone memory and SIM and it didn't find any instead it says "No vCard file found, Only.vcf files can be imported" I still have all the text messages and conversations I had received and nothing else seems to have gone wrong. Anyone know what;s happened, Can I get my contacts back?
3 REPLIES 3
profile.country.RO.title
_alexdon_
Try settings-apps-all-contacts,force stop and clear data.Restart the device.
alexdon
Hampus
Champion
I'm sorry to hear. Hard to say exactly what have happened in this case if you don't remember the error message. But if the contacts have disappeared, something have gone wrong. Since you cannot find any vCard files when you try to import contacts, it does not sound like you have created any backup. Have you checked if you have any contacts on your Google account for example?
Lilykelly
The error was 'android failed' error.
