xperia miro (can't exit safe mode)
Ahmad_141
Hi,,
A few days ago my xperia miro was booted to safe mode by it self ( or maybe by me accidentally) ,,
Since then I cant exit safe mode and I tried every thing I know to exit safe mode( factory rest ,hard rest with flashtool,etc) but nothing worked and now I cant use any applications on my phone...
So if there is anyway to fix the problem I wil be appreciate for the help...
Tags (2)
5 REPLIES 5
profile.country.RO.title
_alexdon_
It cannot be that way,you should be able to exit safe mode just by restarting the phone normally.If you say you have done so many things to it and still having problems,I suggest you take it into service.
alexdon
Ahmad_141
I think I found the problem ..
The down volume button doesn't work so its maybe stuck so every time I restart the phone he thinks that I am turning on safe mode
_alexdon_
Yes,that is why you should visit a sony service.
alexdon
Ahmad_141
Thanks for the help...
Appreciate it..;-)
_alexdon_
Anytime.
alexdon
