i find several bugs in XPERIA TX android 4.3...guys try this and tell the result:
1. when u want to install new app the installing line is drop on the name of app (like leaked version),
2.Although u activate the NFC ,it didnt show N LOGO on the notification bar,
3. when u want adjust the volume ,button of volume in the screen is black line and it cant show it,
4.when u want to call some one the pic of the recipient drops on the number of that person,
5.In lock screen mode if u want to change the volume, the page went black and shows XPERIA logo and finally rebooted,
6.If u want to set XPERIA global keybord as your default keybord like part 5 the page went black and shows XPERIA logo and finally rebooted,
7.Battery take lots of time to fully charged,
8. Noise in camera app, the picture quality has become pathetic from what it was before. the update,
9. IF ONE PRESSES THE LOCK/UNLOCK BUTTON WHILST THE PHONE IS CHARGING, THE PHONE ENTERS A NEVER ENDING BOOT LOOP AND YOU WILL HAVE TO REINSTALL THE UPDATE VIA PC COMPANION TO USE THE PHONE AGAIN.
10. Mobile Bravia engine only works on video playback and not on pictures.
11. Walkman volume is inconsistent in between tracks. It gets louder on the next track, then returns to normal, and then louder again on the next track.
12. In the message app if u want to type the name of recipient it couldnt find the name of the person and u should manually write it.
number 9 is my point, stop using it wihout consent
Reset your cell phone as factory setting and check again.
let's know problems resove or not after reset
bug 3 solution is:
Select any pre-installed theme,reboot...will fix the problem
im only experience problem number 2. the other function works great for me. no rebooting or another problem.
im install 4.3 jb using flash tool since last saturday.
Yes i confirme it:
14.*battery drain super fast. Battery indicator shows 100%, when i unplug the cable battery percentage drop to 99%
