Xperia x10 mini update? (problem)
Not applicable
Ok so looked at my phone today and recieved a nofication on the mini saying that theres a new update avaible so i decided to connect to pc and install the update, the software updater said there is no update, so decided to just stick with the updater on the phone which went through fine and install k (still 1.6) then when i connected the phone to pc companion it said theres another update avaible so decided to go with that aswell, after finishing another notifcation on the phone said theres an update.......what the hell!? sorry for this being a bit long winded but i really dont have a clue what is going off with it any ideas?
1 REPLY 1
Dr_Chris
Champion
I would stick with updating your phone over the air (i.e., don't bother using the PC) until your phone gives you the message: "Your phone already has the latest software". You can still use the update service via PC if you are still experiencing software issues.
