Xperia xa having network issues
amitdgp06
If i select my network to wcdm/gsm my network signal 📶 fluctuated every time but if i select gsm only then the network signal 📶 bar is full every time. Some one help me with this issue...
Thanks in advance..
4 REPLIES 4
Uliwooly
@Amitdgp
You have poor 3G network coverage. Settings > about phone > status > signal strength
amitdgp06
Signal strength is - 96dbm 11 asu
amitdgp06
Is this ok??
Uliwooly
@Amitdgp
Signal Strength
-67 dBmMinimum signal strength for applications that require very reliable, timely packet delivery.
-70 dBmMinimum signal strength for reliable packet delivery.
-80 dBmMinimum signal strength for basic connectivity. Packet delivery may be unreliable.
As you can see, the problem is your network coverage.
