Xperia Z
sahunte22
Xperia Z
Since the last update, my phone will not work on Bluetooth with my car - a Ford Fiesta 09 reg. When using the button on the stalk and saying "phone", "mobile phone ", then "call (and the persons name)" ; after about 5 seconds it says "not possible". I had no problems prior to this update. Help.
9 REPLIES 9
xavinux
Enthusiast
Hi @Spamella
To which version of the OS have you updated?
sahunte22
5.0.2
xavinux
Enthusiast
Hi @Spamella
I suggest you to first run a backup of the device information like this:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
Then reinstall Lollipop using PC Companion:
http://support.sonymobile.com/gb/tools/pc-companion/
This will factory reset your phone and erase all data. You might need tocharge your device for about 1-2 hours before so the device has at least 80% battery. Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device). Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process. If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP.
I hope can be useful.
Best Regards,
sahunte22
Done this but no better, still problem with bluetooth and my car.
I also have a problem in that I do not now get a signal in my home!
sahunte22
Is there a way to get rid of this new Firmware - Lollipop, and go back to a previous version?
Regards, Sandra
xavinux
Enthusiast
Hi @Spamella1
Could you try boot your device on Safe mode and see what happens:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
I'm at disposal for any question.
Best Regards,
sahunte22
Hi
Just rebooted in Safe mode.  Will have to wait until the morning to try it in my car, on the way to pick up my grandsons, to see if it Bluetooths with my car and works.
It's only been in Safe mode a few minutes, but the signal has increased from one bar to two!
Will keep you updated.
Thanks for taking the time to try and help me so far.
Regards, Sandra
xavinux
Enthusiast
Hi @Spamella
Your´re welcome.
Remember that issue is solved booting in safe mode, there is an app that is generating the problem.
Will be at disposal for any question.
Best Rgeards,
sahunte22
No better in my car. I've done a couple of screen dumps - I think it might be to do with Google. I'm sending this via my phone and had hoped to add the screen shots, but can't find a way to do that!
Also my signal is poor this morning.
