hello guys i recently bought an xperia z1 3 weeks ago and i cannot charge phone again i tried solutions posted here like SUS volume down/up + power button but to some extent it charges for about 5 secs and stops and in other circumstances it charges for about 1hr then stops(mostly after 1hr reaches 87% and wont rise any further) i really dont know what is going on i have updated my phone also to latest (the small 51MB) firmware update but even after that it was charging normally till now whether i use the dock or usb till facing same issue any ideas will much appreciated
If your phone stops charging,I would suggest taking it to closest sony service.
Have you tried the magnetic charger? If all of the ways can't work normally, there may be something wrong with your battery or the charging IC on the motherboard. At that time, you should take it to the sevice center to check and solve the problem.
