Xperia Z1 headset bug
ayub99
Recently, I've purchased the the Sony STH30 headset and the problem is that when I connect it to my phone, it works but when I connect it for the second time, the phone doesn't detect it and continues playing sounds through the speaker. The only solution I found is to restart the phone which gets a little annoying. Anyone else facing the same problem?
My phone is running Android 4.4.4, built number 14.4.A.0.108 which is the latest.
3 REPLIES 3
Kulveer_Singh
Contributor
That is a big problem, lots of people facing that problem, but no solution from Sony to that kitkat updates, all kitkat firmwares have that problem. You can see following posts
/t5/Xperia-Z1-Z1s/Earphone-Issue/td-p/859231/jump-to/first-unread-message
tmm1
You should be able to see metal on the bottom of the plug hole.
If not, it's probably filled with dust. Use a toothpick, needle or something like that to carefully pull out the dust and you should be fine.
Seems to work for me.
Why it worked the first time after a reboot is still a mystery to me.
Ashroft98
Enthusiast
Try updating your device.Mine has version 14.4.A.0.157. And so far faced no problems.
