Xperia z2 camera
Sari1
Xperia z2 camera
DSC_0010_3.JPGWhen i take picture with my mobile at night all the lights becomes shiny
Tags (1)
8 REPLIES 8
Uliwooly
I can't see the picture but if yoy are using the flash and there are reflective surfaces that's normal, if your phone has a protective case or film it might be causing this.
SophiaW
Enthusiast
Hi Sari1, welcome to the community!
Have you tried using the camera in manual mode and changing the brightness and white balance settings by pressing the three lines with blue squares on them? You can also tap SCN and try different modes there to see if that helps as well.
Sari1
I am not using flash and my pgine doesn't have protecrive case
Sari1
Sophia i tried that after you sugested it the shiny lights reduses a lot but the image went darker i took another picture a year ago with the same phone and it was good DSC_0266.JPG
Uliwooly
@Sari1
Cool picture/view, could you check if there are small scratches on the lens, also try difference SCN modes and HDR on
Sari1
@uliwooly
There are scratches on the lrns and it lookd like itd not clean. I tried to clean it but it doesn't go away. I tried all thwe setting i thought it might be one of the camera applecations i take good shots in the morning but the problem only when there is a light
SophiaW
Enthusiast
Sari1, might be worth contacting your local Sony Xperia Customer Care team so you can arrange for the lens to be inspected and fixed up for you.
Uliwooly
@Sari1
I'm sorry to hear that, keep us updated.
