Xperia z2 screen prolem
MiiDoviic
hello guys , i have had my xperia z2 for a while now and recently i droped it from 1 floor height it didn't crack cz i have a case on it . but the screen do not turn n anymore it's black , although the phone still work . can someone tell me if i should replace the screen which i can't afford or there's anything i can do to fix it .
1 REPLY 1
dandy63
Leader
@MiiDoviic sorry to hear about this....even tho the screen did not crack or there is no visible sign of damage the amount of 'shock' generated by the drop has obviously damaged something inside, depending on the age of your phone & how competent you are you could try changing the screen yourself but without knowing what is actually damaged it would probably be best to either contact your local Xperia Support or try a 3rd party repairer.
Whatever you choose...good luck :smileysmileythumbsup:
http://www.sonymobile.com/global-en/support/contact-us/
