xperia z3 update issue blank black screen and continuous restarting
Ghaith09
hello every body,
last two days i got my new z3 devise my first android handset
after update i experiensed two problem first was the blank black screen and the notification and quick setting panel was not sliding properly so i decided to reinstal android using sony pc companion after update i switched my phone itkeep restarting continuously every time start installing progams it show customizing apps and then restart and do the same
finally i could fix it when i got my 64gb sd card out of phone and switch it on, it work good with no issues
hope that help people facing these problem
regards,
4 REPLIES 4
Samuel1
Hero
So if I understand you correctly, the issues are only present when the memory card is inserted in the phone? Have you tried using another memory card in the phone?
Ghaith09
unfortunately i don't have another one
i used this sd card with windows phone it show error and but in z1 it work good but with z3 i think it cause problem
any way i will remove the sd card before i start the phone every time
Samuel1
Hero
I recommend that you format the card as there seem to be some issue with it.
Ghaith09
i will do it Slightly_smiling_Face thanks
